Hi there, i have some series one and series two parts for sale:
R33 series 1 coupe - front bumper $ 60 ( its no a type m or nothing just a standard bar, Good if you get a defect for clearance this bar is smaller, has some scratches )
R33 series 2 coupe - back seat side trims and the trims that go around the window ( complete both side) $90 ALL 4 (2 each side)
R33 series 1.5 coupe - passenger side gaurd complete with indicator and badge (white) $100
R33 series 1.5 coupe - drivers side skirt $50
R33 sereis 1 coupe - spoiler ( in undercoat) $ 50
R33 Series 1 coupe - boot and and spoiler (white) $130
R33 series 1 coupe - boot (candy red) $90
R33 series 1.5 coupe - rear boot lip ( its under coat) $70
R33 series 2 coupe - mirror complete but no glass (white) $30
R33 series 2 coupe - drivers side door complete with glass window motor and locks (white) $150
R33 series 2 coupe - passenger side door complete with glass and locks (white) $150 glass is not in the door but it comes with it. ( no window motor)
R33 series 1.5 coupe - center clear garnish. ( where it says SKYLINE) $40
R33 series 1.5 coupe - door trims with red vinyl inserts no bad condition (passenger side comes with window switch) $40 both
R34 turbo coupe - Dash board gauges complete (all 3 complete with cover) $180
R33/R34 - manual steering wheel with airbag $200
R34 auto steering wheel with buttoms (not bad condition) bit worn - $100
R34 Skyline - lhf mirror - $140
R34 Skyline - rhf mirror - $140
R34 Skyline - cluster with like 130kn on it. $150
Im in melbourne (northern suburbs)
If you want anything let me know, its better if you msg me 0434405366 ( as sometimes i dont have time to jump on the computer) thanks!!!
Edited by helrzr28
https://www.sau.com.au/forums/topic/347683-r33-and-r34-parts-for-sale/
R33 Series 1 coupe - boot and and spoiler (white) $120
R33 series 1.5 coupe - rear boot lip ( its under coat) $60
R33 series 2 coupe - passenger side door complete with glass and locks (white) $110 glass is not in the door but it comes with it. ( no window motor)
R33 series 1.5 coupe - center clear garnish. ( where it says SKYLINE) $35
R34 turbo coupe - Dash board gauges complete (all 3 complete with cover) $160
R33/R34 - manual steering wheel with airbag $190
R34 Skyline - lhf mirror - $120
R34 Skyline - rhf mirror - $120
R34 Skyline - cluster with like 130kn on it. $140
Im in melbourne, thornbury (northern suburbs)
If you want anything let me know, its better if you msg me or call me 0434405366 ( as sometimes i dont have time to jump on the computer) thanks!!!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
