  • Replies 168
hang on wasnt it $90?
then why does that link say
"Aww shucks..
I will post a thread about caliper painting in the classifieds section when I get back from melbourne in a weeks time.
The cost for four calipers is $55, and four hubs $15
Silver 'nissan' lettering on calipers (where applicable) $10/pair. (You need existing raised cast lettering for this.. most skylines/200sx have it, some only the front brakes.)"
That doesnt add up to $90? does it?
https://www.sau.com.au/forums/topic/34830-hello-all/page/8/#findComment-724069
Actually I think it'll look much like that, I really want to see what my mags look like when in transit, like do they become "see through" when driving along, that way the calipers will stand out even more :( Rice-A-Roni, BAH you wanna see rice, just you wait and see what I got planned, you guys might not want me on your cruises after you hear my plans :) I'm going the whoa before the go, the car has got enough go for me right now :D
https://www.sau.com.au/forums/topic/34830-hello-all/page/8/#findComment-724770
Hi guys, sorry for the late reply I only just got back from Melbourne (they don't have the internet down there you know)
Ska - I can confirm my all of my clients calipers look brilliant while the car is moving (except the ones that get black.. you can't really see them)
10 am Sunday suits me.
Best thing to do is have everyone arrive early, ala production line style. Once wheels are off you guys can play network games while I'm slaving away over hot skylines.
In regards to jacks, I will bring a shiney new trolly jack, two folding jacks and 2 axle stands (plus wheels chocks/paint/buckets/ etc etc etc :nowigetit
We need two jacks or stands for each car, so start raiding your mums excel and your dads commo, they all come with jacks. :D
This should be a good day :P
Joey
https://www.sau.com.au/forums/topic/34830-hello-all/page/8/#findComment-725326
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
