Hi all,
My drivers seat has worn through on the right hand side support (down the bottom where you brush past every time you get in the car), and I'd like to get it repaired/patched professionally before it gets too much worse.
Can anyone suggest a place in Canberra (Fyshwick preferably) that does that sort of work?
John
https://www.sau.com.au/forums/topic/34831-drivers-seat-repair/
I went by Kam thismorning, they told me that they can't do much with Skyline seats as the cloth is glued onto the seat, and so a patch job is the only option (and they told me to go away and do that myself).
I'll try the other place suggested, but it looks like a fix for now might just have to be a home made patch.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
