Item Description: Parting out PULSE.R - N15 Pulsar S1 LX Sedan with SR20DET conversion
Website: Here
Item Condition: Excellent including many brand new parts. See extra info for detailed descriptions.
Reason for selling: I think it's time to move on.
Price and price conditions: An offer would be considered for the complete working car early on in the piece. If no interest received within two weeks I will consider parting. I would consider offers in the region of $19,000. The car has Victorian Rego, is engineered for some (not all) mods, but will not be supplied with a RWC. Get in quickly if you wish to purchase the car.
Please Note: highest dollar items will be parted first, cheaper items will wait. See extra info for pricing. I can organise freight interstate for any item, however first preference would be given to local buyers picking up.
Extra Info:
Engine/Driveline:
- JDM Avenir PNW10 SR20DET. Approx. 95,000km's. Last dyno at 196.2fwkw, always had fantastic compression, always run on 98 octane, serviced every 2-5000km's. Replaced items include timing chain, tensioner, guides, rocker cover and spark plug seals, crank shaft seal, water pump, fuel rail, sump, alternator. Reliable and has never let me down - $2000
- Custom wiring harness suit GA16DE - SR20DET conversion - $400
- Air-con removed and for sale in a separate thread
- New Radiator, standard SSS 10mm- $250
- Avenir ECU re-mapped by Dr Drift- $200 - reserved for Ibrahim (PGA) if parting goes ahead
- Nismo 740cc injectors with new o-rings- $700
- Z32 Airflow Meter with Bosch plug- $250
- Silvia S15 Fuel Pump- $50
- HKS EVC 6 Electronic Boost Controller- $700 - reserved for R34_Wong (SAU) if parting goes ahead
- HKS Oil Cap- $20 - reserved for R34_Wong (SAU) if parting goes ahead
- Nismo Radiator Cap- $40 - reserved for R34_Wong (SAU) if parting goes ahead
- SR20DE engine mounts pressed with solid prothane inserts- $300
- 600x300x76 JustJap Front Mount Intercooler, custom mandrel-bent Stainless Steel piping- $600
- Go Fast Bits StealthFX Plumb-back/Atmo Blow Off Valve (Black)- $200
- Custom Aluminium Pod Box with 3A Racing Pod Filter, Metal Intake Pipe- $200- reserved for huss2000 (PGA) if parting goes ahead
- New Battery with isolation knob & terminals- $150
- GT2860RS turbo (.64 housing) with modified actuator bracket and rod- $1000
- All Braided Lines for turbo $200
- Pulsar RNN14 GTi-R Exhaust Manifold- $100
- Longer Manifold Studs- will come with motor for free
- Liverpool Exhaust 10mm Manifold Spacer- will come with motor for free
- 3" full Stainless Steel Exhaust, Brand New Flex Pipe, Stainless Steel straight-through Muffler with Droopy Chrome Tip- $800
- CES Split GTi-R Dump Pipe HPC-coated silver- $500
- CES Metal Substrate Catalytic Converter- $200
- 700km old Pulsar NX-R manual gearbox completely rebuilt with:
*New PAR RS5F32A 1st~4th straight cut synchromesh gearset
*New PAR RS5F32 Crown Wheel & Pinion Shaft 4.08 ratio
*New GC Corp sprung centre 24 spline clutch kit
*New Differential Bearings
*New Nismo 1.5 Way LSD
- Custom Pulsar RNN14 GTi-R & N16 hydraulic clutch conversion including:
*N15 Crossmember Mount & Bracket
*N15 Gearbox Chassis Mount & Bracket
*Driver's side and passenger side driveshafts
*NX SR20DE flywheel - machined
*New N14 SSS flywheel bolts - P/N: 123152J220
*New Pressure Plate Bolts
*New Speed sensor
*RNN14 GTi-R clutch pedal
*N14 brake pedal
*N15 shifter + linkages
*New/Rebuilt RNN14 GTi-R clutch master cylinder
*RNN14 GTi-R clutch master cylinder reservoir
*N16 clutch slave cylinder - P/N 30620-2J00A
*New N16 clutch slave cylinder spacer - P/N 30674-3J100- /01/02
*RNN14 GTi-R Clutch - Master to Slave hard & soft lines
*New P11 Actuator Arm - P/N 30520-3J101
*N15 SSS gearboot + underboot and plate
*New Nismo Shift Knob - Black Rubber GT Pro - reserved for R34_Wong (SAU) if parting goes ahead
*New Rear Main Seal
*New Shifter Bushing Set
- $7500
Suspension & Brakes:
- Tein Aus-spec Super Street Coilovers with Pillow-Ball Upper Mounts, 4.5 years/30,000km's old - $1000 - reserved for NoSlipSSS (PGA) if parting goes ahead
- Tein Electronic Damper Force Control (EDFC)- $200
- Whiteline Blade Adjustable Rear Swaybar - $200
- Whiteline Adjustable Front Strut Brace- $100
- Sentra B14/200sx Adjustable Rear Strut Brace- $100
- Pulsar N15 SSS 28mm Front Swaybar- $50
- Whiteline Front Swaybar D-Bushes- included for free with above item
- Whiteline Front Swaybar End-link Bushes- included for free with above item
- Whiteline Steering Rack Bushes- nearly new- $40
- Pulsar RNN14 GTi-R Front Calipers (AD22VF) sprayed gold - $300
- Bendix Advance Brake Pads (front)- included for free with above item
- DBA Slotted Rotors (front)- included for free with above item
- Pulsar N15 SSS Rear Disc Brake rear axle conversion (calipers sprayed gold) - $300
- Unknown pads and rotors (rear)- included for free with above item
- Racebrakes Modified stock Brake Master Cylinder - $100
Body Modifications:
- Pulsar N15 S1 SSS Front Bumper (middle insert cut out for FMIC), not great condition- $150
- Topstage S1 Lip - $150
- ASV N15 (VZ-R Copy) Side Skirts - $300
- ASV N15 (VZ-R Copy) Sedan Rear Pods - $300 including rear bumper
- JDM Pulsar N15 Lucino Grille - $150
- JDM Pulsar N15 GT Bootlid with high-mount brake light mounted in the spoiler - $200
- Whole car received a respray in custom White with House of Kolor Ice Turquoise Pearl in 2008
- Black Bonnet & Grille with House of Kolor Ice Turquoise Pearl
- Colour-coded door handles and mirrors
- would start taking offers on the shell once drivetrain items are sold.
Interior:
- Pulsar N15 S2 SSS Airbag Steering Wheel- $300
- 1Kg Dry Chemical Fire Extinguisher mounted in the passenger foot well - $20
- Defi DIN cluster - $600
- Defi Racer Series Boost Gauge mounted to drivers side A-Pillar - $200
- New Nismo GT500 urethane shift knob- $80
- Black Recaro-style front reclining racing seats with custom rails, a bit faded and flattened but no rips - $400
- Back seat & all door cards fully re-trimmed in black mesh material (to match front racing seats) - $300
Wheels & Tyres:
- 16x6.5" RJR Wheels- $400
- Maxxis Victra MA-Z1 205/45/16 - included for free with above item, still a lot of tread.
Lights:
- Pulsar S1 N15 SSS Foglights and Switch - $150 for all
- Pulsar S2 N15 SSS black surround crystal Headlights - $300 for both
- Pulsar S2 N15 SSS Front Indicators - $100 for both
- Pulsar S2 N15 crystal Tail Lights - $200 for both
- Clear Side Indicators - $40
Windows:
- 20% tinted rear windscreen, rear quarter windows and rear side windows and 35% (darkest legal) tinted front side windows - included with the shell for free
Audio Details:
- Clarion DXZ656MP Head Unit
- Pioneer 6" 4 Way Speakers
- Pioneer 6x9" 3 Way Speakers mounted flush with rear parcel shelf
- $300
Other:
- Viper Paging Alarm with Remote Start - $200
I've forgotten items but I will add as I remember.
I will provide additional photos or condition information of any individual parts if requested.
Receiving lots of interest in parts, I'll try to keep the first post updated with what's reserved. Remember I don't plan to take a single part off the car for two weeks - so please keep registering your interest but I won't be taking anything off the car prior to that.
Custom Aluminium Pod Box with 3A Racing Pod Filter, Metal Intake Pipe- $200 - no longer reserved but I can't edit the post.
- Viper Paging Alarm with Remote Start - $200 - reserved for Midnight Mods (NS)
- CES Split GTi-R Dump Pipe HPC-coated silver- $500 - reserved for staticmoon (PGA) if parting goes ahead
- Custom Aluminium Pod Box with 3A Racing Pod Filter, Metal Intake Pipe-$200 - reserved for -Darren- (PGA) if parting goes ahead
- Pulsar S2 N15 SSS black surround crystal Headlights - reserved for CallumT (PGA) if parting goes ahead
- Pulsar S2 N15 SSS Front Indicators - reserved for CallumT (PGA) if parting goes ahead
More Reserved:
- 600x300x76 JustJap Front Mount Intercooler, custom mandrel-bent Stainless Steel piping - $600 - reserved for keepitreal07 (PGA) if parting goes ahead
- Go Fast Bits StealthFX Plumb-back/Atmo Blow Off Valve (Black)- $200 - reserved for keepitreal07 (PGA) if parting goes ahead
- New Battery with isolation knob & terminals - $150 - reserved for keepitreal07 (PGA) if parting goes ahead
- GT2860RS turbo (.64 housing) with modified actuator bracket and rod- $1000 - reserved for Mika (PGA) if parting goes ahead
- Pulsar N15 S1 SSS Front Bumper (middle insert cut out for FMIC), not great condition- $150 - reserved for keepitreal07 (PGA) if parting goes ahead
- Topstage S1 Lip - $150 - reserved for keepitreal07 (PGA) if parting goes ahead
- ASV N15 (VZ-R Copy) Side Skirts - $300 - reserved for keepitreal07 (PGA) if parting goes ahead
- ASV N15 (VZ-R Copy) Sedan Rear Pods - $200 - reserved for yatesy.27 (PGA) if parting goes ahead
- Pulsar N15 S2 SSS Airbag Steering Wheel- $300 - reserved for CallumT (PGA) if parting goes ahead
- Pulsar S1 N15 SSS Foglights and Switch - $150 for all - reserved for keepitreal07 (PGA) if parting goes ahead
- Z32 Airflow Meter with Bosch plug- $250 - reserved for keepitreal07 (PGA) if parting goes ahead
More reserved:
- All Braided Lines for turbo - $200 - reserved for keepitreal07 (PGA) if parting goes ahead
- Clear Side Indicators - $40 - reserved for bradles (PGA) if parting goes ahead
More reserved:
- Defi DIN cluster - $600 - reserved for XLD380 (PGA) if parting goes ahead
- Tein Electronic Damper Force Control (EDFC)- $200 - reserved for Incredible Hulk (PGA) if parting goes ahead
Back up for sale as buyer pulled out:
- New Battery with isolation knob & terminals- $100
Reserved:
- Pulsar RNN14 GTi-R Exhaust Manifold - $100 - reserved for angusGTIR (JDMST) if parting goes ahead
A couple of parts coming off this weekend, nearly everything that's so far been reserved next weekend. I'll start PM'ing people re: payment tomorrow night. If you want something soon now is the time to speak up :)
I may also be withdrawing the sideskirts, rear pods and bootlid from sale pending selling the car as a complete car down the track once all performance & aftermarket parts are out.
- Tein Aus-spec Super Street Coilovers with Pillow-Ball Upper Mounts, 4.5 years/30,000km's old - SOLD AND GONE
- Tein Electronic Damper Force Control (EDFC) - SOLD AND GONE
Strut braces out, grab yourself a bargain!
- Black Recaro-style front reclining racing seats with custom rails, a bit faded and flattened but no rips - SOLD AND GONE
- Back seat & all door cards fully re-trimmed in black mesh material (to match front racing seats) - SOLD AND GONE
- Whiteline Adjustable Front Strut Brace - reserved for RBPOWA-(TJ) (SAU) if parting goes ahead
- Sentra B14/200sx Adjustable Rear Strut Brace - reserved for RBPOWA-(TJ) (SAU) if parting goes ahead
Closing this thread as all of the sold parts have come off the car yesterday and I'll be starting individual threads for the small amount of remaining parts still available.
Thanks for your interest.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
