HEY
as in title my r33 is not starting
this occurred around 3 weeks ago
lukily i was at my panelbeater and with a booster pack got it started (using terminals at front)
so i thought it was my battery that was gone
now i have bought a new battery and connected it up and still same problem
has power for everything else
though when i turn the ignition all it does is click
i also cleaned the terminals using sand papers
but still no difference
any ideas wt it could be?
as i need to move the car of the driveway asap as its blocking my garage
https://www.sau.com.au/forums/topic/349491-help/
If you can get the car to start from booster packs from the front terminals every time (as in it cranks easily this way but not when you try and crank it from the on board battery) then sounds like you have a pretty bad issue somewhere between the battery in the boot to the starter.
Do a voltage drop check while cranking off the car battery to confirm this. best way would be to have someone stand at the back with a multimeter across the battery terminals and then crank the car. From memory the Minimum voltage you should see is around 8 I think, but if its failing to even turn I think youll be seeing much lower voltage then that. Do this then put the results up.
https://www.sau.com.au/forums/topic/349491-help/#findComment-5615051
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
