Hi all
I'm selling a set of wheels and tyres off my GTST.
Wheels are JDM and as follows:
Front:
17X8 (+35)
Tyres - Kumho KU36 225/45/17
Rear:
17X9 (+38)
Tyres - Kumho KU36 255/40/17
Condition:
A little gutter rash on the 8s and the clear coat on the rims is coming off (only really see this up close). Other than that, they are good! No dings and they drive and track nicely. On my R32 they sit just inside/on the guards (so legal) with no spacers required.
I think they look good and am only getting rid of them to go to 17X8s all round for cheaper track tyres.
The tyres are legal and just above the wear marks.
Other:
I am in Brisbane on the northside and wheels are pickup only. Also, for the right price I will include a full set of red, 45mm (long ones) D1 Spec light weight wheel nuts. Offers by text or PM only.
Price: $600.00
Thanks
Nick
0412 547 402
https://www.sau.com.au/forums/topic/349655-wheels-17x8s-and-17x9s/
BUMP
These are Enkei Circulars so are good value for $600.00.
I've attached a couple more photos. I only have two 'Circular' center caps though, so ignore the generic ones on the car at the moment (I just wanted four matching).
Plus $600 will get you the full set of 45mm D1 Spec wheel nuts.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
