hey guys just cleaned my afm on the 33 and took it for a drive. was alot smoother but noticed that my boost had dropped from .84 down to .60. anyone know why that happened?
i adjusted my boost controller so that it boosted to .84 again and it was much smoother again no big miss where it would normally happen.
any insight would be awsome :)
https://www.sau.com.au/forums/topic/349687-just-cleaned-afm/
its a blitz dual sbc and i didnt reset anything the controller still said had the same set level as boost as before i cleaned the afm but when i adjusted it i had to double the number to get the same boost as before.
im still using the standard smic would that have something to do with it? im outting in my front mount on tuesday
Well it must not be a problem coz I reset the ecu an went for a spirited drive the boost is stronger but seems to be more undercontrol as the boost used to bounce under full throtle before cleaning the afm and it doesn't spike so I'm happy will see how things go on Tuesday when I get the cooler in
Yeah my boost had nothing to do with the ecu when it fluctuated it was because it was missing but it stopped after cleaning the afm but now I got my intercooler in it misses shit loads and has hardly any power under load so now it looks like new coil packs for me the joys of cars=)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
