Howdy all.
I am about to become an R33 GT-R owner :wassup: and at this point only have limited knowledge on the cars. I have looked at the car I want to buy - owner says it is a V Spec but it has no decal on the rear. Is there any other way to tell the car is or is not a V Spec.
Thanks
https://www.sau.com.au/forums/topic/34984-r33-vspec/
Yeah, as Leewah said, fins on the diff casing, plus you can see the extra pump for the active diff pump gear tucked up on the right of the car behind the rear wheel arch and the line going from it to the diff. There should also be a A-LSD light on the tacho. Those two thing are probably the easiest ones to pick. They have different shocks and sit 10mm lower or something too, but you could never pick that. The attessa computer is different, the attessa-pro, don't know how to pick the difference externally. And apparently a V-spec GTR always has a "W" as part of its Chassis identification tag whereas a normal GTRs have an "O". V-specs also have different brake ducts.
Most of that info came from an article in a HPI mag. Should be good. They all checked out on my V-spec which I got to see for the first time yesterday at the compliance workshop.
Can email the article if you like, too big to post here and if I reduce it, its too hard to read.
https://www.sau.com.au/forums/topic/34984-r33-vspec/#findComment-699899
Howdy all.
Thanks
:(:/ CONGRATULATIONS :(:P
https://www.sau.com.au/forums/topic/34984-r33-vspec/#findComment-700589
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
