Help With Identifing Stickers?
There's a sticker pretty similar to that 100,000km one which you get when you buy a Nissan timing belt - however the actual sticker has space for the number of km and the current date.
Pretty sure that sticker is just a reminder to change the belt at 100,000km - not that it's been done.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
