  • Replies 99
That warehouse might still be usable, problem is that they were building and extending that spot. I'll check to see if it can be used. But for the first shoot I'll stick to the grassy spot for now. Also my locations need to be quite dark.
March sounds good as previously mentioned (or even April somewhere around Easter time)?
I need to get my front guards done so a date would be great so I it gives me a deadline which will make me get off my ass and do the work that needs to be done lol :laugh:
Cheers,
Andy
Would prefer the grassy to the containers just based on the side on shot....id be more after shot positions like you did with my partner Kris (krzysiu).
How about the 12th March? its a saturday so all day to clean car :) and meets Nick's first 2 weeks of march requirement :)
or april may be better...still dont have an ETA on my repairs being completed :( when are you getting back nick?
haha 12th is the day i leave :P
gone for 3 weeks
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
