Firstly i', located in TAS, or Tasmania for those of you who don't understand abbreviations. Hobart (7000) to be more precise. And i am willing to pay for things to be posted over if the price is right.
I'm looking for a few things, Here goes.
S13 Rear Height adjustable coilovers, new or old (in good nic if old)
If i cant get hold of those then the standard R31 rear suspension will do the trick for now.
A R31 Center bearing for the tail shaft, as mine is absolutely rooted.
Possibly S13 Front coilovers, if the price is right. If not then later down the track.
LSD Manual Gear ratio diff. Prefer 4.11. (sedan by the way)
And maybe some handbreak cables.
Just reply to this thread as i check here a few times a day.
Cheers
Kurt
https://www.sau.com.au/forums/topic/350933-s13-coilovers-and-a-few-r31-parts/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
