item 1:
nardi wheel for sale i think its size is 360 or 350.
its not deep dish style flat.
horn button included.
condition: been used so its ok.
selling due to got my deep dish in mail just now heheh
price: $150
item 2:
bride ergo 1 (i think)
in my cheffy atm. rails fit silvia, r32, 180
has little side tear.getting in and out
no other marks or holes. pretty good condition.
$400 pickup
item 3:
just jap d1 quick release steering wheel hub.
black/silver
has bolts wiring all the original things and the box
has been used
$70
item 4:
17x9+30 pair or equip rims
lots of scratches
have 215/45/17 ok tires on them
good skid rims
$300
picture similar but not so shinny not chrome and lots of scratches
hoppers crossing
sms me 0430078630
who wants the bride seat? only $400 and
comes with rails to fit r32,r33,r34,180,silvia,cheffy,lural.
sms me 0430078630 and i can send you more pictures.
might be keen on seat and rail depending how low ull go
even without rail as i have 2 anyways
let me know
pm sent
do you have passenger rail for bride seats i can buy? r you can give me seat and little cash for the bride seat?
is it a real bride and is it fia app. how old is it and do you have rails to suit r33 gts-t drivers . nick 0404099310
pm sent
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
