No Jimbo, the first one was fine because you had all this in lowercase:
yo.
just a trivial thing, if you've got you're caps on trying to yell in a post after you submit it it either is all in lower case or only th first letter of each word is upper case
It only changes "TEST" to "Test" when your ENTIRE post consists of capital letters, and I think that's a good thing.
https://www.sau.com.au/forums/topic/35154-capital-letters/#findComment-702469
I agree it is a good thing and it stops annoying noobs, but in my case where i was trying to yell in bmans, majanal thread that i noticed its a problem.
pro's definatelt outway cons though :(
https://www.sau.com.au/forums/topic/35154-capital-letters/#findComment-702519
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
