Not a game Microsoft will allow to be released on console. But if you set your Kinect up on your Windows 7 PC then Clutch can finally feel some chick's boobs.
http://www.cnet.com.au/kinect-sex-game-in-works-339308051.htm
https://www.sau.com.au/forums/topic/351639-kinect-goes-sexytime/
http://www.cnet.com....s-339308051.htm
when did you buy this game craig?
does your mum bother you when teh fapping begins?
Edited by Clutch
Are you positively annoyed friend?
games not out yet BTW.. or did they give you a game testers copy? LOL
i don't live with my mum unlike others, but the missus doesnt always put out on demand ;)
PS. only works on PC so not much point when you can just watch porn and have both hands free :ph34r:
i aint even mad
you cant re use my dig and use it against me...
i don't live with my mum i live in the bungalow out back, but the mr doesnt always put out on demand ;)
FYP
story of your life
Edited by Clutch
  • 3 weeks later...
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
