hi guys,
i have an r32gtr which has a painted front lower lip - i dont know why they paint them in the 1st place, imo they look sooooo much better in the factory black plastic finish.
anyway, has anyone ever attempted to remove the paint & if so what works well?
i dont want to damage the factory plastic finish nor do i want to rub it back - i want that factory look :)
i have heard about a paint stripper which doesn't damage plastic, does it exist though?
I couldnt find anything when I redid mine mate, I fear that even if they dont damage the plastic as such it will be badly stained being a porous/grainy finish...I ended up spraying mine in Satin Black bumper paint which has a slight texture to it when it dries, looks good...but agree 100% that factory unpainted looks best. Let me know how you go...I considered a dull grey paint of some sort as another option but couldnt find a colour I was happy with.
Edited by NSNPWR
that sounds good - does the paint flex though or does it crack as soon as it touches a gutter?
i sprayed mine using some $2 paint and put some clear coat on it, its sort of faded in the sun now so it looks factory haha, i also wet sanded it to get rid of any large scratches, came up a treat.
Depends what colour the car is. I think white with the matching white lip looks good. Your best bet would be to probably start fresh, even if you manage to get the paint off the standard plastic might be damaged from cerb taps over its 18 year history.
Mine hasnt cracked at all but it scuffs like every other paint does, I think its a semi Nurathane (?) rubbery paint...my brother did his side skirts on his GTiR Pulsar in it too, looks good.
I guess the good thing has been its very easy to touch up if and when you do mark it going in a driveway etc...quick mask up of the area and give it a lick...the brand is Motospray 'Bumper Spray', the can is yellow, black lid.
that sounds awesome - i'll give it a go if i cant get the old paint off
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
