Cusco Adjustable Upper Arm (Rear)
Vehicle compatibility as below:-
Skyline - R33 GTS-t S1 - ECR33
Skyline - R33 GTS-t S2 - ECR33
Skyline - R33 GTR - BCNR33
Skyline - R34 GTR - BNR34
Skyline - R34 GTT - ER34
Silvia - S14 S1
Silvia - S14 S2
Silvia - S15
Price is AUD 250 + postage
Nissan Silvia (S13)
Nissan Skyline (HCR32, HNR32, BNR32)
Nissan Laurel (C33)
Nissan Cefiro (A31)
Nissan Fairlady (Z32)
  • 2 months later...
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
