I just bought a 94' R33 GTST and im over the moon, it is as if it rolled out of Nssan in Japan just 5 mins ago, It is as stock as a rock which is really quite rare.
So I need some reccomendations on what I should do to it. Any opinons?
The First thing that needs to go is that ugly spolier on the 93-94 models, is anybody selling a 2nd hand spolier from a later R33?
Yep. Exhaust, pod (with air-partition)/panel replacement, bleed valve (or EBC). Decent wheels are a must-have; more traction and some ever-important style. Springs (~$400)go with the wheels (to remove that 'dune-buggy' effect of putting larger wheels on stock suspension), though some new shocks (~$1000) would go down well if you have the money.
All in all, it depends on how much money you have. Take the car for a dyno run to see if anything is not right.
bleed valve is just a cheap way of running more boost. They are just basically a glorified T piece that you can adjust the boost. So your car runs 7psi stock and bump it upto 10psi to get more power. I wouldnt up the boost until the pod and exhaust is done first
Is that how a boost controllers work? by connecting to an automatic bleed valve. so you change the boost while driving?
Mechanical boost controllers can come in single-stage or two-stage 'packages' (for lack of a better word).
With the single-stage ones, you set the boost (via the knob on top), and that's all there is to it. The two-stage ones let you set have a low-boost setting, and a high-boost setting; you can flick between them using an in-car switch.
PUT A PHAT BODY KIT ON IT 18" CHROMES, LOTSA NEONS, STICKERS, AND BIG MASS DOOF DOOF. NO BODY WILL WANNA MESS WIT YA. :wassup:
Nah u came to the right place these boyz know there shit. as said EXH is a must and make sure its turbo back soooo many ppl forget about it when they buy there cars off us it cost shit all to get but opens the Exh right up for you. Reset your computer as well so it learns the way you drive.
Stock R33's are not rare these days as all the imports have to be stock. I would say this has had a good effect on the value of already modded examples in the country.
You're best bet would be to upgrade the exhaust first. Replace the dump and front pipe with a 3" combined front/dump pipe, replace the catalytic convertor with a 3" hiflow item, replace the cat-back system with something free flowing and at least 3" and get yourself a good muffler which will flow well while not being too loud.
Depending on the money you have the options you have with the exhaust vary. You could get a HPC coated split dump pipe (seperating the wastegate from the exhaust outlet at the turbo to reduce turbulence).
After the exhaust you should either use a performance panel filter in the stock airbox, buy an aftermarket airbox and panel (ARC for example) or build/buy a partition for a pod filter.
You should not just stick a pod filter in the engine bay. This will decrease performance on the street.
Ask yourself - "How serious am I going to get about performance?" - don't bother buying cheap products if you are only going to want to replace them later. I think that's common sense. An electronic boost controller would be my pick. But certainly, exhaust first. I believe that engine management is also a good thing to get in the car asap - but that all comes down to budget.
Yeah my thoughts exactly. I skipped the bleed valve thing completely and went straight to the Apexi PowerFC full ECU replacement with boost control kit.
Saved the money i wouldve spent on bleed valves, boost controllers, electronic boost controllers, SAFC's or other piggyback systems, plus the performance is better than you can get with piggybacks.
i'd also be saying that the most intelegent thing you can do for your car is change the fluid ASAP! my mate found water in his coolent tank after he got it back from complicance, you want that kind of crap out of there...........
Set some goals:
1) What power level am I seeking?
2) What kind of a budget am I on?
3) How long do I envisage keeping this car for?
4) Street, Drag, Sprint/Motorkhana/Road Rallies, Circuit? All of the above?
5) How do I want my car to look? Clean 'tricked'? Show car? Over-the-top?
6) What kind of handling mods will I need? New shocks and springs, or coilovers and the lot?
Once you've got what you want to do in mind, you can begin modifying your car 'properly'.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
