Up for sale is my 1983 Ke70 corolla. The car is running a smallport 100kw 4age from an Ae92 corola GT, modified suspension from an XT130 + numerous AJPS bits, extractors, exhaust, bucket seat and stripped interior
this car was built for a drift rig, but due to me blowing up an engine in my R33, she needs to go! my loss is your gain :cries:
engine conversion and wiring was carried out by ADM and is top notch!
engine:
100kw smallport 4age
4-2-1 extractors
2.5" exhaust with rear muffler and chrome tip
cut and shut plenum
pod filter
bosch 040
lift pump
2lt upright surge tank mounted in boot
custom rubber fuel lines
handling:
rebuilt steering rack - very light
XT130 struts, with falcon springs
XT130 lower control arms
Whiteline swaybars - front and rear
Whiteline front strut brace
350mm 3 spoke strreing wheel and boss kit
Drift button handbreak
Drivtrain:
Clutch Industries heavy duty single plate clutch
T50 Gear box
C's Short shifter
S series drive shaft
S series Diff - Welded
S series rear axle and hubs
15 x 8 -9 Challengers all round
195/50/15 KU31's with 100% tread
Interior:
Dash Racing bucket seat - fixed back - very light
modified KE70 seat rails
stripped interior
3 spoke wheel - 350mm
Saas monster tacho
cams approved fire extinguisher, mounted behind handbreak
no stereo/heater/AC - all unnecessary parts removed - rear seats come with car
Body:
Flat front conversion
T-18 chrome rear bar (needs front bar)
Solex Locks
painted (badly) in doe skin beige - FQP's are white
Fender mirrors - square
all in all the car is a mint little package, and is awesome to drive. It comes unregistered and with no RWC.
all aftermarked parts are fresh and haven't seen a drift day as this build was only recently finished
only problem with the car is the paintwork and small vac leak which should be easy to sort out
looking for $4k
I can be contacted on 0433 362 156 or [email protected]
that is p-retty sweet
its virtually impossible to register it again huh? need to get everything engineered?
Damn this is tempting. Where abouts are you located?
Edit:
As much as I'd love this I really can't afford it now and its not feasible. Don't have room to store it, don't have trailer or a car capable of pulling a trailer. Couple of years time though...
I'll put it up on Facebook for you anyway.
whole car man.... 2k without rims...
that's the cheapest complete 4age conversion ever, complete with heaps of free shit
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
