  • 3 weeks later...
  • Replies 109
Bit of an update
HKS kit not coming now, i decided against it at last minute due to couple reasons
1. It's WAY too easy to get carried away when building a car which is what i nearly did here, this car is a weekend drive car not a strip monster so going with these turbo's was way too much overkill and would of most likely turned car into a strip only vehicle which i definately don't want
2. This is probably the main reason actually, i'm venturing out on my own with new business which requires a SUBSTANTIAL outlay in anyones books so any extra i had laying around for this car has now been injected into new business account to get up and running
So where to from here?
Given time i will fit set of -5 turbo's, cams, intercooler and new ECU then that will be about it, after all i want to use this car and keep it streetable
I have also toyed with selling it and buying a 34 R later on
Time will tell
I hear you mate.
It is very easy to loose focus when building theses things. I know I have over indulged with mine :O
I'm glad you realized this before it was too late. I have the same moto as you re maintaining a street able car.
-5's are an excellent choice and there are many cars now that show how good they really (and how powerful they can be).
Good luck with the rest Brett.
Edited by Ants
  • 4 months later...
Bit of an update as it's been a while
Tried selling the car to buy an R34 GTR but no one wants to spend there money buying new cars at moment
So what does one do when presented with this scenario?
Keep modding of course :yes:
Thought i'd finally upgrade the brakes as this is pretty much the final piece that needed attending to underneath the car
So just bought these
Will tie in perfectly with overall theme of car with gold nur engine covers etc ;)
Some more parts awaiting arrival
Couldn't believe this HKS kit was still available
PLAZMAMAN 100mm Intercooler same as in Powertunes 900+ hp GTR
TOP SECRET Carbon Ornament
Fitted to N1 Cover
Got home yesterday and there were couple boxes waiting for me to unpack :woot:
First of all the new cooler, these things are HUGE
2ndly the carbon plate and -12 fittings arrived for the N1 covers
No sign of the HKS turbo kit yet though :angry:
Sent email through and they say it was sent around week ago through e-go but i never recieved even email from ego which they usually send and i notice he still has this system listed on ebay - if not seen by end of week then i have no option than to start proceedings to get money back
I felt like xmas had come early this afternoon when this arrived at front door :yes:
Once all unpacked it looked a little something like this
Yepp, 1 complete top mount HKS turbo kit capable of upto around 1000HP :w00t:
Not going to unwrap everything though as need to build motor before these are attached but did unwrap a couple of things to have a look at
I had to laugh whilst unpacking though, i was thinking how the hell does this all go together :rofl2:
That'll be job of engine builder me thinks :yes:
HAHA I would be thinking the same thing...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
