never been b4 geek.gifwouldn't mind meeting a few new ppl with the same interests..do you guys and girls get out to socialize cheers.gifor just do hot laps look at me kind of thinglaugh.gifbiggrin.gif
just a stupid.gif ??? but whats the address, what time and what car u going to be in..
im the black guy in the blue r34( no its not stolenwhoops.gif) with a few go fast racing gasket kit and a few racing stickersbiggrin.gifbiggrin.gif
if you come down on a night when there is heaps of regulars you will understand why we chill down there. most of the time is a sit down, relax have a chat and something to eat. very little driving gets done but sometime a few of the guys go for a little cruise
  • Nope 1
I am leaving Villi's-bound now!
nice to have meet you, your son, the bloke from japan, i.t worker with sunkist colour skyline( lol) sorry guys hopeless with name im sure there was one more but didnt really catch much of him due to my daughter bashing the crap out me to go cruzing...
Yeah not a bad place to hang and chill. Heaps of parking but the over cooking of the chips and pie i might have to get used to...
Anything organised for Friday the 11th of Feb?? Or is it every friday at Cafe de Vili's?
Ill be back in Adelaide and would love to come and meet others on SAU:SA :action-smiley-069:
Cheers,
Matty
Cheers,
Matty
I am guessing you mean March because we are in March now :P and 11th of March is a next week Friday.
I don't think anything is organized for now. Keep an eye on that thread as it will have updates of whats happening :D
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
