ok... JL is out ... downsizing to
1) me
2) yoparata aka aaron
3) Charly aka james
4) yamutha33 aka warwick
5) NA_R33 aka John
6) Nismogirl aka Erin (only if... )
at Milton Maccas @ 7.30pm
correct me if i am wrong, but so long as we stay on ICB and then onto the Gateway, we will see the new shell right?
  • Replies 224
Glenn,
I am probably down as a maybe at this stage depending on the weather.
This is gonna sound lame, but I just washed and waxed the car the other day and don't really want to get it dirty......lol
I could come in the wifeys car (it's filthy anyway), but don't know what sorta response I would get with a WRX on an SAU cruise.
*stands in corner in shame*
twoquik - Doesnt look like anyone is interested in picking you up, sorry.
Glenn - Yeah just follow the ICB then hop on the gateway and go north, there are huge signs for it, but you do not actually see it until you are basically right on top of it.
List for BP Yatala @ 7:30pm:
1. me
2. strutto
3. BelGarion
Anyone else coming from GC?
Glenn,
dun care if its a rex or **** ... its the more the merrier that counts, Warwick :rofl:
hope the weather does hold out coz i just made up a uber dodge cold air partition, and wanted to try it out
lol.. you thk that's bad?? i have my filter modified to just behind the front bar. i'm onto my second AFM now becos I farked up the first one couple of months ago in a heavy downpour.
Did you have to extend the wiring for the AFM?, or did you use some kind of adaptor?
Guys how about we go ont he empire cruise? I was planning on going to that if this one was going to rained out. the empire one is at the church on logan road near computer alliance/concorde/shell. and its at the bottom of mt gravatt. they meeting at 8:30 then cruise through city then to cleveland. prolly end at 2am :")
I'm going on that beacuse this cruise doesnt have too many people interested, and twoquik I can pick you up if you like.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
