For Sale: Recaro Passenger Side Rail. Suit R32, R33 and whatever else. I have used the Drivers side and don't need the passenger side.
Condition: Good
Contact: 0423815552
Price: $100 ono
Pretty sure they were used on reclinable seats... All they need is some tabs welded on to suit whatever fixed back you have. That's what I did with the drivers side.
Hey Billy,,,got any pics of it???. You can send to (ndr at bigpond dot net dot au)if you have.
Cheers
Neil.
I'll get a pic for ya tomorrow after work, bedtime now haha
Hey Billy,,,take some pics mate,,,if it's what I'm after I'll take it.
Cheers
Neil.
Consider it sold mate,,,pm me you banking details,,,I'll transfer the money,,,you send it and we both will be happy campers.
Cheers
Neil.
