ok i really want to do this once ive finished my rice (hopefully before MAS) and engine bay detailing etc
i need someone who's grouse at car photos, basically wanna get one external shot as main photo then about 3 small 'detail' photos of interior engine and car audio in the boot to chuck in a big ass frame for my wall with the main photo and the 3 smaller ones down the side
can anyone help me out, i understand there will be costs involved..
cheers :D :headspin: :headspin: :headspin:
https://www.sau.com.au/forums/topic/35390-photographer/
i've done a few for mates using my digital cam and officeworks. All up cost about 20 bucks.
I can do one of em for ya if you want... basically its A3 or smaller on gloss or matte paper.
Altho my camera's res is just about enough to get a good A4... altho if I do it on super high res you should get a very clean n crips A3 shot.
https://www.sau.com.au/forums/topic/35390-photographer/#findComment-706727
aaahhh!! for the life of me, I can't remember which one of the vic sau guys is the photographer! He had a website, with pics from the recent elwood cruise, & on his site had something about tv commercial proposals... :confused: If I remember I'll let you know!
like NS2500
https://www.sau.com.au/forums/topic/35390-photographer/#findComment-706790
Check the Elwood meet thread.
the quality of the pics he took then is amazing!
They look like something out of a moive. Especially Andrew's GTR
Using the search button might be hard for ya... SOOoooo....
Attached are two pics that Greg pre-pared earlier :wassup:
how good are they huh?
https://www.sau.com.au/forums/topic/35390-photographer/#findComment-706856
Thought I'd add the the quote theme!
Due the man! INARK :)
Originally Posted by meshmesh
aaahhh!! for the life of me, I can't remember which one of the vic sau guys is the photographer! He had a website, with pics from the recent elwood cruise, & on his site had something about tv commercial proposals...  If I remember I'll let you know!
like NS2500
https://www.sau.com.au/forums/topic/35390-photographer/#findComment-706916
hmm greg = free... jun = payments... lol knowing noof greg's got himself a photoshoot :P
I like greg's shots too... very classy... if you need anything touched up or digitally enhanced or erased then I'll have a dabble at whatever greg produces...
Jun's well... jun's pretty well published his work speaks for itself.
https://www.sau.com.au/forums/topic/35390-photographer/#findComment-707511
hmm greg = free... jun = payments... lol knowing noof greg's got himself a photoshoot :D
Well, there will be costs - but only in materials, not time. Also, I would prefer to retouch/enhance photos myself as I have the originals to work from. That said, I don't mind having photos modified - if they look good.
https://www.sau.com.au/forums/topic/35390-photographer/#findComment-708428
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
