Does any one know the diameter of the R34 steering wheel? Or could some one be awesome and go quickly measure their R34's diameter :P
Just trying to find out if the R34 has the same size steering wheel as the R33 or whether it is actually smaller. From memory they looked smaller than the R33 ones.
Could not for the love of god find the diameter listed anywhere after half an hour of Google searches.
Cheers
Phil
https://www.sau.com.au/forums/topic/354023-r34-steering-wheel-diameter/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
