I have also got a full set of 4 Bridgestone Potenza 245/45/18's
They all have legal tread, couple mm above the wear bars, I bought them to stretch on my wheels but without thinking the '45' profile is too big for stretch and won't really work but for someone that isn't going for a stretch etc these will be great.
$100 firm! No budging as this price for legal tread potenzas is crazy.
0433830055 < NEED THEM GONE!
bring em back over and ill give you the cash back man
hay up 4 grabs is my twin high mount greddy TD05H-18G kit suit rb26
comes with 2x greddy turbos 2000kms old and very good quality manifold
very minimal shaft play and turbos in perfect working condition
$3k firm...
LOCATED SA>POST AT BUYERS EXPENSE :blink: $50 aus-wide
i want to use these, but if i sell these i can get my car painted instead.
contact me via sms only 0423487731
cheers- Ben
Edited by D1C33
UPDATE
Home Theatre system
few yrs old now but still pump hard
2x Sony Carbcon/ SS-4050 speakers (2 tweeter. 2 mid range (adjustable) 2 subs)...
1 Sony CDP-c365 5 stacker cd player
1 yamaha RX -485 Amp (phono, aux, cd and 2 tape outputs
1 tape player! LOL
all cords n shit to suit
works a dream really really clear. cost a bomb new!
$150 picked up
2x Hyper Rev magazines... brought of another member last yr for 120 or so :S..... $60 for both (EXTREAMLY good value)
1x bolt in exhaust silencers, 4.5 inch... $20
6x HPI etc magazines. i think about 3 or 4 contain stageas in them $10each or all for $40
2x JBL 2ways 3 1/4 inch 25 rms 75 watt $20 (brand new)
2x different stag manuals $20 each
top gear DVDs FULL set of volume one and 2 from bali actualy very good qaulitiy and one braught from BBC... $10 each
1x GFB boost t $20 no idea what pressures its good for but great for cheap each boost
2X 10mm slip on spacers... multi stud $20
1x rough silver zippo lighter $30
1x red M35 stagea solid model in case braught from another member not long ago $60
1x 8 tonne rated tow rope... used to rip a few trees out but thats it. never put under serious strain... no rips or fraying $50 (hard to post coz of weight)
1x nokia hands free kit very good condition used in box $50
1x Rjays full face helmet (aus standards but not for motorcycle) never been crashed on fre scratches $45
1x fox goggles. clear leans, not scratched up. $15
1x dicksmith webcam $10
1x dicksmith computer mic with stand very n ew $10
1x logitech ATTACK 3 joystick (very new) $30
Full set of S2 cloth seats IMMACULATE condition... very heavy so id say only sa buyers at this stage.... can send if need be tho at buyers expense .....$250
heaps of ramsay dvds again all in great nick. will double check. F-word series 1 2 and 3 for $40 all 4 nighmares dvds $40
season 1 deadliest catch $30 (3 dvd)
COMPUTER
IPOD
EMANAGE
all sold :(
Edited by chef_stagea
richo mate i dont think your exhaust is a full stainless steel system....only the tips look stainless steel.....i have a stainless steel system and looks nothing like that.....just letting you know
<br />richo mate i dont think your exhaust is a full stainless steel system....only the tips look stainless steel.....i have a stainless steel system and looks nothing like that.....just letting you know<br />
<br /><br /><br /> He never said it was a full stainless system, he's only saying it has stainless twin tips. Its pretty obvious from the pics.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
