Running out of time to pay for parts on hold so...
I have
2x Stanton T.60 vinyl decks with cords and slipmats (got them 2nd hand off ebay 6 months ago)
2x Ortofon Om Pro S scratch/mix cartridges with new Stanton Headshells (brand new 6 months ago)
1x Audioline 4ch mixer (dmix4sp) with cords (brand new 6 months ago)
10x jungle/drumn'bass vinyl
old pair of headphones
record cleaner
old cartridge and headshell 1x
All items in good condition only used the setup a dozen times and is now in boxes under a spare bed
All you will need is an amp and speakers, I had it hooked up to my surround sound
$580 ono
More info and pics on request
Regretful sale, help fund my mods!
1-Set of 3 piece jap meshies
Front 17x9+29 with Yokohama c drives 215 45 17 approx 90%
Rears 17x9.5_22 with Khumo platnium 225 45 17 approx 90%
Bit of rash being 2nd hand rims nothing major
Will need spacers to clear front gtst brakes
$1300 ono
2-Genuine Red Rays lock nuts packet of 20
Never used the nuts just opened the packet to use the lock key
Nissan thread 1.25
Still have the reciept from JIS
$180 ONO
3-150mm pink dildo shifter with nissan/toyota thread
$40 ono
Contact via pm
Edited by mark ii
r33 gtst sr1 carbon bonnet bought from autobarn paid $1300 a few years back only used on my car for a few months just been sitting in my shed. has a few light scratches $500 ono
R33 gtr spoiler needs a rub back and paint no end caps $250
R33 4door front lights $250
HKS 25/35 turbo kit (direct bolt up to rb20, 25 and neo 25... uses stock dump, mani etc etc..) i have had braided water in and out made, stock oil in and dump. the turbo is 15,000ks old from new and is in IMMACULATE condition. $1600 FIRM with lines
tein type CS coilovers
suit auto rs4 stagea (series 1 and 2)
32 wat dampner adj, heigh adj
comes with c spaners, some stickers from new, and the little dampner key.
also will include 10k old isc toe and camber arms
$850
sold the pair of z32 air flow metres. one delivered, one on hold pending 3 enquiries...
so all up for sale I have:
1x pair stock R32 RB26 GTR manifolds $100 the pair
1x pair stock R32 Rb26 GTR turbo dump pipes $100 the pair.
1x 5-point clip-buckle harness, brand RCI. $50
1x r32 rb26 GTR oil pump, used but in good condition $50
1x r32 RB26 GTR harmonic balancer, in good condition (used) $80
1x oil catch can with mini pod-filter, brand new, $50
1x 3-guage holder set, new. $30
2x Q45 Air Flow Metres, Working condition, with plugs. $100 the pair, or $50 each
1x pair pod filters. Brand new never used. $50 the pair, or $30 each seperately
1x stock R32 RB26 GTR Intake pipwork, $50 the lot
1x stock R32 RB26 GTR coilpack cover blue, $100
1 x stock R32 RB26 GTR turbo two-into-one exhaust front pipe, good condition $50
1x 3" decat pipe with flex section, brand new never used $60
1x 3" twin barrel mid-muffler resonator section, brand new never used $80
1x full set Tein suspension to suit R32 GTS-T. Came out of four-door R32. Tein shocks/springs. In good condition $500
thanks. PM me and we'll arrange what you want, etc.
cheers
Brendan
hey mate interested in the suspention! is it lowered spring or just standard?
$850
hey mate really interested in the coilovers! would like to see some pics! let us know! cheers
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $30ono
2: HKS Boost guage and loom (60mm) $50ono
Or take both for $70
Not sure what they are exactly worth. Sorry the pictures arn't very good, they were taken with my phone.
Come come people, I need these items gone asap. The boost guage will not come with the vaccum hose due to me using it for another boost guage.
RB25 850cc top feed injector kit
Been test fitted, never used. Some cosmetic damage (few scratches) from test fitting etc. but doesn't affect the operation at all. Doesn't fit standard manifold hence the reason I'm selling them.
Suit rb25 with aftermarket manifold. WILL NOT FIT STANDARD MANIFOLD.
Comes with
6x 850cc Siemens DEKA injectors
fuel rail
all fittings
all o-rings
all harness plugs
Its all there ready to bolt on.
$600
pm or call 0422 314 938
Edited by SkyHi_33
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
