Hi guys, i have just had a new catback built today.
3inch stainless with A M Performance 3 inch resonator and 4 inch twin pipes at the rear.
the twin pipes are internally baffled, kind of the same way cannon mufflers are.
The car still has a 3 inch dump and front on it.
The issue is now with this set up is louder than my setup with just a cannon..it sounds 50,000 times better BUT for street its a tad to much.
was thinking a 3 inch muffler box that would bring it down a little but not to an overly quiet level
or should i replace the gutted cat with a 100cpi metal cat.
really need this effin exhaust finished
Edited by honan
https://www.sau.com.au/forums/topic/354301-new-pipes/
You need a rear exhaust box with some volume to it, if its those exhaust tips that are not much bigger than the pipe they really do nothing in reducing the DB.
A straight through 3.5" rear box with the lenght of 450mm, width of around 250mm and a height of around 150mm fits and keeps it just legal, It does on mine anyway :thumbsup:
Mark
https://www.sau.com.au/forums/topic/354301-new-pipes/#findComment-5675632
Well i'd argue the "pipes" are mufflers, i mean a tiny bit of baffle does sweet fk all, so does the resonator.
CAT realistically wont drop the noise much either.
You need to either put a decent mid-muffler in, or live with it
https://www.sau.com.au/forums/topic/354301-new-pipes/#findComment-5675660
Define "quiet". One persons version is not the same as another.
Quiet according to the law is 90dB @ 4700rpm no load, this requires basically 2 of the bigggest mufflers you can fit for a 3" or larger exhaust.
Now the mid muffler is going to be nowhere the same in terms of effect as its smaller than the rear will be and you basically have 2x4" noise amplifiers
So putting in the bigger possible mid-muffler is realistically your only choice.
I'd take a stab @ it probably being at least 96-98dB @ 4700rpm no load, which is massively louder and will realistically never be "quiet" and it will always drone etc as thats the effect of 2x4" outlet pipes, it might even be more even with a mid muffler.
No one can tell, and as i said - no two persons definition is the same.
https://www.sau.com.au/forums/topic/354301-new-pipes/#findComment-5675701
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
