still for sale the following items:
pedders coilovers
radiator
front mount intercooler and pipes and silicon hoses
bov
fpr
18 inch wheels x2 sets
slicks
starter motor
alternator
gtr rocker covers and centre plate
engine mounts
clutch slave cylinder and master cylinder with hydraulic lines
lightened flywheel
extreme motosprt clutch with ceramic sprung center
centre console with ashtray and gearknob
gtr dash
top part of snorkel for air cleaner
engine stand
  • Replies 40
Posted Images
Can you put up picks of 18" rims please?? And do you have a series 2 bonnet? If its in good condition im interested.
Cheers
pics of rims above, no s2 bonnet
hi im trying to chase down the blend door motor for the air-conditioning system. It is located on the left side of the driverside footwell. Little black box with a rod poking through to the passenger footwell.
if you have this are you able to post it interstate?
Cheers.
  • 3 weeks later...
  • 4 weeks later...
Hey mate do you have the series 2 drink holder that goes inbetween the centre console if so how much u want for it?? and also do you have the rear parcel shelf with the speaker holders on the parcel shelf??
no sorry dont have either
cheers Mat
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
