sard fuel collector tank 5L cuboid type
2x 280L/hr intank pumps
lines to suit r32 gtr, but could possibly be used for other models
supperted over 400awkw easily, done about 1000-1500km MAX
$1200
cost over $2k
6x denso/power enterprise injectors 1000cc twin spray RB26
$900
1000-1500km max usage
reason - upgraded fuel system to triple pump and id2000 injectors to support alot more power and E85
located in sydney will have pics over the coming days
Thanks! will look at close offers...
Willing to separate ?>
seperate what exactly?
umm thats just tank then add 2x fuel pumps and lines buddy, thats the cylinder not the cube
Any pics of it installed in a 32R??
sorry i dont have any as i took it out and now my new system is in place...
wll have pics tomoro ran out of time today
hey mate are the injectors to suit standed rail or 14mm cheers?
hey they are to suit 11mm, dont think they make 14mm
what pumps r they?and is the line teflon or rubber?
hey the 2 pumps inside are sard 280L/hr pumps, the line is braided hose so i assume just rubber? im not exactly sure, all speedflow fittings and also a sx fuel filter ill throw in
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
