sard fuel collector tank 5L cuboid type
2x 280L/hr intank pumps
lines to suit r32 gtr, but could possibly be used for other models
supperted over 400awkw easily, done about 1000-1500km MAX
$1200
cost over $2k
6x denso/power enterprise injectors 1000cc twin spray RB26
$900
1000-1500km max usage
reason - upgraded fuel system to triple pump and id2000 injectors to support alot more power and E85
located in sydney will have pics over the coming days
Thanks! will look at close offers...
Willing to separate ?>
seperate what exactly?
umm thats just tank then add 2x fuel pumps and lines buddy, thats the cylinder not the cube
Any pics of it installed in a 32R??
sorry i dont have any as i took it out and now my new system is in place...
wll have pics tomoro ran out of time today
hey mate are the injectors to suit standed rail or 14mm cheers?
hey they are to suit 11mm, dont think they make 14mm
what pumps r they?and is the line teflon or rubber?
hey the 2 pumps inside are sard 280L/hr pumps, the line is braided hose so i assume just rubber? im not exactly sure, all speedflow fittings and also a sx fuel filter ill throw in
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
