S2 Dayz Lower Fog Lights - dont see these around too often!
Custom Mounting Brackets included
Hey guys,
I have for sale a pair of super rare Dayz fog lights.
They have custom mounting brackets which allows them to sit in the outer vents of a Dayz front bar. Perfect if you have a big FMIC in the center opening. All the hardwork, cutting and fabricating has been done by me. All you have to drill one hole into the underside of the factor reinforcement bar and they sit firmly no vibration, no movement. There is no cutting of the factory bar so it is a perfectly reversible mod (the best kind!). If you want to mount them in the factory location (center opening) then this can be done also.
They are in top nick, only one has a tiny bit of hazing around the edge inside the lens. Was planning on separating and cleaning, but its unnoticeable on the car so I havent bothered.
I will include part of the loom + connectors if you dont already have it.
Selling because I want to go for a custom LED setup.
Will arrange pics mounted to the car shortly. If they don't sell i'll just go ahead with my plans to install HID's into them.
Looking for $200 + postage ONO or pickup in melb CBD
Cheers. Mat
Edited by SMOKEYC34
https://www.sau.com.au/forums/topic/354765-s2-dayz-lower-fog-lights/
bump.
good thing to have with winter coming, esp if you do any night time country driving. factory look, with the performance of one of the best aftermarket brand available (they are CIBIE's) - think same brand as all the driving lights you see on the front of 4WD bullbars.
chuckie - if your mate is interested in a purchase he can call me on O438 32O 369.
can't write back to your PM for some reason, just has a big red X.
  • 4 weeks later...
they're goneski. havent had a chance to update the carsales photos.
by the end of the week the car will look much different anyway.
will be replacing the driving lights with HELLA DayLine LED DRL's (oem equipment from audi), new rims, and nismo sideskirts are now gone and replaced with Dayz items so that i can lower it more....).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
