Hey guys
I have installed a S2 RB25DET into my HR31 coupe over the last few months i regoed it over a month ago and all is good, pulls nice and seems to drive like it should. I gave it to a local tuner to put her on the dyno and run it up to see if there is any problems turns out after 9 power runs everytime at 6000rpm and making 140rwkw it drops off, he said they usally drop off a little bit but then pick up and goes to the red line as mine doesn't.
Fuel is rich and it isn't leaning out.
No vac leaks or boost leaks.
The motor isn't breathing oil.
Timing is right.
AFM seems to be in good working order.
CAS seems to be in good working order.
He seemed to think the timing belt had jumped teeth and told me to check it, i thought if the belt had jumped over it would be running bad all the time and not just at 6000rpm. So i checked the timing belt and all the marks line up.
I went over my wiring and from what i have wired it up from it's correct.
The CAS isn't off centre as the timing is back to 15 degrees at roughly 850 rpm on idle.
New splitfire coilpacks less than 1500 km old.
New NGK copper plugs pre gapped to .8 less than 1500km old.
Before the motor went in it had new oil and filter, fuel filter, coolant and flush, water pump, timing belt and a boshi 040 installed.
Im taking the car back on Friday to have a some more work done with re run with a mates S2 computer, as i have a mate that works at the tuners shop and he reckons it might be ecu related.
The motor is pretty much stock apart from:
FMIC
Greddy profic type II boost controller (witch is off currently)
Boshi 040
3 inch exhaust with a centure muffler and rear muffler
Splitfires
Im thinking of getting a tune done with a power fc but im pretty sure my problem will still be there even with the new computer and tune.
As you can see im all out of ideas.
Any ideas or help will be great!
Cheers
Adam
Edited by Ad's
dude.... 140rwkw and beyond is the rich and retard maps in the factory ECU.
TUrn your boost up and I bet it hits this hole a whole lot earlier.
Get a tunable ECU, its a known fact that the factory ECU is useless for anything above stock power.
You are wasting your money trying to "fix" the factory ECU.
Powerfc...
Boost controller got turned off as it was only making it run worse! And its still off currently! I will be looking at a power fc soon when i don't have a lack of money.
The VCT is working as it clicks and my mate pointed it out when it was in there!
Thanks
Apparently its my air flow meter in the cooler piping! It's going back in a week or so when i have moved it back and seeing it it changes anything!
islade : I borrowed a mates manual computer and it didn't make a difference.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
