FOR SALE: R31 Silhouette GTS1, 1988
Kilometers: 345,xxx+ Has correct GTS Dash with 250,xxx
Transmission type: 5sp manual
Engine: RB30e
Colour: White
Modifications: Nismo Short Shifter,
Roadworthy Certificate: yes
Accident History:
Tap in front,
Keep Left Sign on the Rear Passenger,
Repaired by proper shops,
Asking Price: 12k ono
Contact Details: 0415 161 052
[email protected]
Other Comments:
restored 2 years ago, used many new parts,
Front Bilsteins
New Nissan Front and Rear Disks
Reco Calipers all round & Rebuilt Master
Low K' Rear end, (Serviced) with new Superpro Bushes all round
Replaced power-steering Rack, and Front Bushes
Exedy Clutch (Normal Duty)
New headlights
New Tail lights
New Door Molds (Very Rare)
New Radiator Manual (Rare)
New Genuine leads
New Genuine Coil Pack
New Side and Front Indicators
Serviced every 5k
Clean Steering wheel
Wheels Powdercoated
KU36 Tyres all round, 3000 Kilometers old
R32 Gtr Floor mats,
New Brake and Clutch pedal rubbers
will be serviced with Genuine Nissan Filters and Oil On sale
New Cas plug as well
PLASTIC Front lip (VERY VERY Rare)
Heaps of other stuff, changed to get it looking Good again, Has SVD books
Bad,
Needs a GearBox Reco. Bearing are Noisy, Sincro's are noisy - Reco Box going in MAR Regardless of Sale or not
Done about 12k Kilometers Since Resto
Had a Leaky Clutch Master since Resto
Drivers side window is Scratched up, Tint is Damaged also
Small Tear in the Drivers Seat,
Diff makes noise at 80kph (like all) (But not as bad as Some)
This car has been lovingly restored By myself and a Few select shops, Including most recent work at Micolor
It has been My Passion for about 5 years, and i think its time for Someone else to Enjoy it and do something more with it.
Edited by mastadd
https://www.sau.com.au/forums/topic/355076-vic-r31-silhouette-gts-1/
Was that Restored?
i don't think so.
Several Coupes are for sale now for well over 6k
your mate may have gotten a good price, because it sounds that way
Close to 20k Has been spent on this,
Its one of Less than 150 left.
make an offer if your interested
Good luck with the sale...love the 31's.
This would be a good buy for a collector...limited edition - 200 in the world, less those written off etc
Looks nice but isnt the price a little steep? My friend picked up a 2 door in good nick for about 6 g and that had a rb20det in it as well.
Dude - do you even know what this is?
Put an RB 20 into this one and I guarantee you'll knock about $5k off the value. Being 2 door means your mate's got a run of the mill jap import (dime a dozen). The Aus spec GTS 1 and GTS 2 were limited edition (only 200 of each made) by Nissan Vehicle Division. They were the hottest thing to wear a Nissan badge in Australia till the GTR came along.
Fair enough these aren't the fastest Skyline ever built, but they are definitely valuable to collectors. I would think that $12k for a good example would be pretty well on the money.
These were close to 40k when new.
The engine is still un opened,
Has had while it was out for the resto:
Genuine water pump
Genuine tensioner and timing belt
overhauled oil pump.
new belts
new injector o rings(the washer things that go into the manifold)
new studs for the exhaust manifold,
it had a compression test before i brought it and came up good so i haven't felt the need to open it up,
The RB30 is well documented as a motor that is capable doing some very very high k's
i will get a Compression test carried out while the Gearbox is getting done and post up the results,
Its a good Solid car that has never let me down,
its not my daily so it sits about locked away and i'm still of 2 minds of weather i want to sell it,
Its more about needing the Space than needing the cash.
when i say its been lovingly restored i mean it, i have put a lot of "cliche" "Blood sweat and Tears" into the car its not perfect and im still buying bits and pieces for it all the time to keep making it better and better.
was this at micks shop couple of months ago???
if its that one, then saw it when i went to pick my chaser up. and holly cow its a clean and straight car
Micolor Mick?
If so, yeah i just got it back at the end of Jan. Thanks man it certainly looked much much better once it came out of Micolor with front all aligned.
  • 2 months later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
