Hey guys just seeing what sort of interest I get I don't want to sell but really want a 32/33
1984 ADM AE86
supercharged 4-AGE AE86
Has a sc12 supercharged 16valve 4age that wa rebuilt around 4,000k's ago running 7psi
Fully rewired
Twin external fuel pumps & surge tank
Battery relocated to hatch
Recaro race seat (drivers side )
Stripped interior ( I have the carpet & rear seat )
S13 tein coilovers
H4 halogen headlights
Oil cooler kit
Painted in vt /vx commodore gold with black bonnet
I'm sure there is more I just can't remember it all
Located in Hobart
Only after swaps for a 32 or 33 but as I need a price 10k (only cause I'm after swaps)
Will post pics when on comp
Cheers
https://www.sau.com.au/forums/topic/355310-supercharged-4-age-ae86/
i have an r32 gtst for sale for 7500 and a silver n/a s2 r33 for 11500.
check my threads, they should be my last two posted threads.
only dilemma is that im in sydney. ><
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
