im kinda getting over my stock looking 4" rear muffler atm and i kind of want a cannon again.
so im after a 4" internal diameter cannon muffler.
show me what u got, dont mind paying postage either.
https://www.sau.com.au/forums/topic/355377-4-cannon-muffler/
