Learning Katakana /Hiragana? Try this
If you're just learning Katakana and/or Hiragana in your own time without professional assistance you might find it difficult to find ways to study.
I was using flash cards and a girlfriend but those tools are now unecessary!
Check this free software out:
http://www.dreambreed.com/download/DreamKana.exe
Its just a simple, free flash card software that displays a Kana and you type in what sound you think it is.
Helped me :(
https://www.sau.com.au/forums/topic/35570-learning-katakana-hiragana-try-this/
Same... its hard.
I think learning Kanji is all about just immersing yourself in it and learning about the particles and the origins of them and stuff.
Being an ideographic language helps a tiny bit, but that will only get you so far. My example is the Kanji for Ni ( 日 ), as in Nihon ( 日本 ) looks like a box with a line in it. That is supposed to represent the sun? Hon is the word for book (looks a bit like a tree with a stick across it and is in fact a derivative of the tree Kanji (木 ) but it's also the word for origin.. The word Nihon is literally "the origin of the sun" or "the land of the rising sun" AKA Japan. Thats how i remember everything... Only about 50000000 more of these things to go.
Usually those kinds of ideograph lead me down the path of frustration. Sure those ones are easy to remember but they get silly. Ask a fluent Japanese/Chinese person to write the Kanji for Dragon and prepare to throw your arms up in the air :(
I dont see me learning 5000 Kanji anytime soon. I probably know about 20 basic particles which means i can read a couple of words max. Im basically useless.
mind you, I use flash cards myself - and written repetition. I find flash cards to be the easiest method - as I can use them anywhere - I find studying at the computer very difficult and distracting (why study when you can look at cars and naked women?)
For anyone studying, I highly recommend the "basic kanji" series (published by bonjinsha) - very straightforward. I know about 400 kanji and it's ultra helpful - I wouldn't say I know that 400 in-depth though (all on and kun readings), but I get by. I'm not a studious person - and that's a serious problem (motivation!). Kanji can be lots of fun. The biggest problem I had is when the kanji I was learning surpassed my vocabulary - it's very easy to learn kanji for words you already know, but when you need to learn new (non-daily usage) vocab, it becomes exponentially difficult.
And I've always sucked at languages! :(
what's experience? you've got to start somewhere :)
mind you, I have heard some linguistic theory that says the human ability to (relatively) easily master a second language peaks when we are young, shudders to a halt at about 21-23, then it's all down hill from there...
motivation is the key - if you can keep yourself genuinely interested then the process of learning is no pronlem (ability is something else all together)
Hey guys I'm just starting to get back into studying and just beginning with the kanji . . . I'm finding http://japanese.about.com/blkodarchives.htm very useful. They have the kanji up to grade 5 level, with stroke order, common compounds, and wav files so you can get the pronunciation right . . . also if I ever get around to upgrading my handheld to a colour unit I mean to get KingKanji from http://www.gakusoft.com/ , you can write the kanji on the screen and it corrects you as you go.
Cheers
Jason
Wait so you don't need your girlfriend anymore?
thanks a lot sewid, just what i was looking for.
the only word that i know in katakana is "Supra" , heh i dont even know how yo read skyline....YET
My usertext says - basically - Skyline Junkie. But if you were to read and pronounce it litterally the sounds are actually:
Su-ka-i-ra-i-n - スカイライン
ja-n-ki - ジャンキ
Remembering that in Japanese the vowel sounds are:
a - as in far
i - as in field
u - as in put
e - as in get
o - as in pot
Of course in Japan they would, and do, just say Skyrine.
Supra would be:
Su-pu-ra
Which is a whole lot simpler just: スプラ
Supra would be:
Su-pu-ra
Actually, thats "Su-pura" (extend the "u" sound) like スープラ。
C'mon, everybody... Suuuuuuuuu-pura. Suuuuuuuuuuuu-pura. Thats it! One more... Suuuuuuuuuuuuuuuuuuuuuuuuuuuu-pura.
Right! :D
    • Hi guys my 94 r33 gtst fuel pump has gone out. I have a walbro 525 ready to go in but am unsure if I need to upgrade the fuel tank bulk heads? Ive heard that others have issues with the stock wiring melting... Ive seen alot of people recommend this: https://frenchysperformancegarage.com/products/fpg-nissan-skyline-r33-r34-silvia-s14-s15-billet-fuel-tank-bulkhead-hat-top-an6-with-high-current-connector-apex-2-8-delphi-fpg-100?variant=42873255198898 My current pump that stopped working is aftermarket but I had no relay mod or upgraded connectors. Need some advice please. TIA
    • It’s new. It’s the cd009. I did take the transmission apart to mill down the bellhousing and had both housings come off the gears so wondering is something isn’t in right. I am running redline. I can get it in gear running too but it’s just not easier and it’s almost like 2, 4, 6, and reverse all the back gears aren’t happy going in
    • I’ll remember that as a last choice. It’s brand new
    • Got keys and did a walk around the yard planning the landscaping works with the family that I will be doing Main effort: remove all the woodchip in the gardens that are around (attached) to the outside of the house and replace with 10mm blue metal, having woodchip close to the house is a recipe for inviting white ants, currently there are no white ants within the block and I would like to keep it that way I'll be buying some large raised garden beds to grow veggies and stuff, and the woodchip will be mulched with everything else that gets dug up, pulled out, or cut down during works Next will some minor drainage and landscaping maintenance up one side of the house, where the fuse box, AC, and solar stuff will go, about 12 mtrs long by 2 meters wide, I'll break up the soil, add gypsum and then I'll dig in a French drains about 300mm deep x 300mm wide and fill it with agg pipe and blue metal, then level out the whole area with a 50mm layer of blue metal, the soil, whilst currently pretty compacted, will break up well with the gypsum to aid in drainage, I'll then cover the area with a 50mm layer of more blue metal In saying this, the drainage issue is minor, but that little hidden away area down the side is untidy and weedy, and as all of the main elec stuff is there I want it neat and tidy to appease my OCD Again, the material excavated from the French drains with be added to the garden bed mulch, as will some rose bushes and some other crap looking garden plants, and a old apricot tree that is looking worse for wear The apricot tree is currently in a little roundish garden bed that is in the middle of the back yard with few other crappy looking plants around it, that will all be removed, levelled, re-turfed, and is a perfect spot for a hills hoist There is also a area about 3m x 2m between the rear fence and shed that will get some attention, it looks like some stuff was stored there and the grass is dead, that will also get broken up and mulched, and is a prime spot for a pumpkin patch I've guestimated that I'll need: 3 tonnes of blue metal, 12 meters of agg pipe, 5kg of Gypsum, and a hills hoist, so a few bags of concrete as well to set it in place (the house currently has one of those pull out 4 line jobs, whilst it works, I want a retro old school hills hoist), I am also going to run some chickens, there's a great spot for a coop, so a chicken coop to suit 4 of those lovely egg laying bitches will also be on the job card That should keep me busy for a while, and will finish off the back yard ready for a early spring planting of some veggies and berries  Once the main effort is done I'll start out the front, there's a large rock garden that could use some TLC, but that is only minor works Should be fully moved in within 2 weeks, the landscaping works will start then Fun times, retirement is good
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
