yeh Ad's, im gonna do a private day in dec for my bday, so if ure keen to bring ure car or just passenger in cars all day....lol, canon is going strong!!
Nismokid, ide go neo....stupid power from those things before openimg them up...plus it may be cheaper lol
Yeh im glad i did MBS206, so good for something different and the sound lol.... ule love it!!
Canniabiscorpse, got heaps of gopro on car vids, trying to edit the boring bits lol. Yeh ppl always dbl take haha, thats wat makes it so entertaining for me haha
https://www.sau.com.au/forums/topic/355725-ls1r31/page/2/#findComment-5865927
They fit in R33s too... :D
Just... LOL
I'll stop hi-jacking your thread now... ROFL
I'm thinking I'm going to flog the aftermarket rocker covers off, and get standard ones and the stock engine covers like you've got. It looks much neater.
https://www.sau.com.au/forums/topic/355725-ls1r31/page/2/#findComment-5876576
lol, i dont mind the pics. Its good to see other peoples interest :thumbsup:. yeh i have exactly the same clearance with my sump and k frame. How did you go with the steering and starter motor? Any fouling issues? I had trouble with the uni joint on the shaft hitting and binding on the starter motor....
Heres the link to my build.....
http://s748.photobucket.com/albums/xx127/Marks31/
https://www.sau.com.au/forums/topic/355725-ls1r31/page/2/#findComment-5878193
Yeah, we've got epic foulage... LOL...
What did you do to avoid the foulage?
We're looking at moving the steering rack towards the drivers side more, and then modifying it so the bump steer isn't affected.
Would be interested to hear how you cleared it...
Just went through your whole picture album too... It's interesting, it appears as though the R31 engine bay is wider between the chassis, you don't seem to have much of an exhaust manifold issue. Or did you get some custom made?
Have you measured between the tops of the strut tower before for width, and between the chassis rails?
Be interested to know if the R31 really is wider...
https://www.sau.com.au/forums/topic/355725-ls1r31/page/2/#findComment-5878391
  • 3 years later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
