Hey skyline kids, I like to go down to pickles damaged Auctiuons every Friday when I get a chance this 93 R33 is up this Friday, unfortunately I wont be able to go see it, just thought Id put this here in case any-one else was interested-might be able to get a bargain 93 R33 @ pickles Friday 4th March
Edited by rickr333
Hey all heres another one, R34, 4 door and auto :P ill be there just for fun, theres also an 89 wagon model too if any1s interested!!:thumbsup:
4 door auto r34
89 skyline EXECUTIVE wagon
Edited by rickr333
4 door auto r34
r34 went for 4300+ fees woulda been about 4600, back left mag was missing (stockie on) and something bent at the back affecting str8ness of the wheel, also had rubber sprayed up the inside of both gaurds, pretty tidy besides that tho
Oh and the 89 wags went for 325.......BARGAIN
Edited by rickr333
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
