Tommy G Posted March 2, 2011 Share Posted March 2, 2011 Hey, I've recently taken my Stagea to a nearby clutch and brake centre in Ringwood to have the 'buzzing' in my transmission checked out. As I feared, the mechanic believes it's a worn input shaft bearing (and maybe a clutch plate issue). He has quoted anywhere north of $1200 to repair. Does this sound reasonable? Has anyone had similar issues and know where the cheapest place to have it repaired around Melbourne would be? I'm guessing the input shaft bearing part would be the same as the R34 GT-T?? Any help would be appreciated. Link to comment https://www.sau.com.au/forums/topic/355820-stagea-transmission-input-shaft-bearing-replacement-melbourne/ Share on other sites More sharing options...
ironpaw Posted March 2, 2011 Share Posted March 2, 2011 try RVO in Dandenong? They're recommended on a few other forums... Link to comment https://www.sau.com.au/forums/topic/355820-stagea-transmission-input-shaft-bearing-replacement-melbourne/#findComment-5695576 Share on other sites More sharing options...
Tommy G Posted March 2, 2011 Author Share Posted March 2, 2011 Just been speaking with ABS in Ringwood - price is now $2,000+ as he wasn't aware it was an R34 Neo engine! That's pretty serious money for an annoyance. Think I'll leave it alone a while. Link to comment https://www.sau.com.au/forums/topic/355820-stagea-transmission-input-shaft-bearing-replacement-melbourne/#findComment-5695797 Share on other sites More sharing options...
darrinspencer Posted March 2, 2011 Share Posted March 2, 2011 (edited) Just been speaking with ABS in Ringwood - price is now $2,000+ as he wasn't aware it was an R34 Neo engine! That's pretty serious money for an annoyance. Think I'll leave it alone a while. Walk away. Neo engine. What difference does that make Most shops quote approx 6 hrs ($80-100/hr) to remove and replace a clutch for a GTR. No different for a stagea So add any additional time to replace bearings in box etc. While the box is out, probably best replace the clutch and rear main seal on motor and gear box input shaft seal. Mine makes a noise as well. Edited March 2, 2011 by darrinspencer Link to comment https://www.sau.com.au/forums/topic/355820-stagea-transmission-input-shaft-bearing-replacement-melbourne/#findComment-5695844 Share on other sites More sharing options...
Tommy G Posted March 4, 2011 Author Share Posted March 4, 2011 Walk away. Neo engine. What difference does that make Most shops quote approx 6 hrs ($80-100/hr) to remove and replace a clutch for a GTR. No different for a stagea So add any additional time to replace bearings in box etc. While the box is out, probably best replace the clutch and rear main seal on motor and gear box input shaft seal. Mine makes a noise as well. Thanks for the info fellas. I ended up taking it down to 'Nizpro' in Bayswater. The mechanic (who owns/used to own a Stagea) took it for a spin and also identified the noise. He said they have had good results in the past using a particular high grade transmission oil (not sure of the exact specs - possibly thicker than normal oil?) that apparently minimise the issue. Gearbox should get another 10-20,000kms without a drama he believes. Will be interesting to see how it goes... Link to comment https://www.sau.com.au/forums/topic/355820-stagea-transmission-input-shaft-bearing-replacement-melbourne/#findComment-5699082 Share on other sites More sharing options...
