I am still trying to work out the difference between all the types
The S and SP both have sport suspension so a bit firmer. 18" wheels but the S doesn't have heated leather seats and dont' think it has the cameras.  They both have bigger brakes
The P 17" wheels, smaller brakes and suspension is a bit softer. has the cameras.  I don't think the P has the paddles shift on steering wheel.  I did think the P had all had leather, but then i did see one on car sales with leather/cloth interior.
Ive been googling and searching for hours but cannot find all the info.  Is the coupes and sedan types the same ? eg does a S type coupe have exact same features as an S sedan ?
Here is a USA based matrix of options for a 2007 G35 Infiniti.  Seems to be the mostly same as Japanese options.  There is also similar PDF's for later years floating around the internet, I kept this one since it relates to my V36.
2007_sedan_specs.pdf
Edited by Rufus007
  • Like 1
Rear and Side cameras were fitted to all models btw...
is  a journey a type P ?
A sport a type S ?
a AWD a type SP
got a 2009 V36 sedan with the 7spd, overall it is a good car
few mods and it'll be wonderful but as stock things to note would by the clunky transmission which can be fixed up with a tune
if you're looking to mod for performance too, you'd have to drop a lot of money to make it faster but for a stock N/A it is definitely quick enough
English & GPS on the head unit is sometimes hard to change but if you find the right people they may be able to convert it for you
unfortunately i'm looking to trade my car in for something newer and euro in the near future but it has and is still serving my daily driving well
is that the 3.7 ? how many kms ?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
