Hey all,
This weekend I put some Tein S Tech springs in my R34 GTT (sedan) to bring it down to a more reasonable road height without making it uncomfortable. Anyway, I've decided the shocks aren’t cutting it they don’t double bounce or anything but definitely feel doughy - that just-chopped-out-2-coils spring feel.
Anyway I've got some low KM factory R33 GTR shocks in storage (collected from a different car) which from memory looked the same (rear fork, shortish front shock etc).
Does anyone know if these will bolt in (looks like they will, but I'd hate to dig them out of storage to find they either don’t bolt in, or the dimensions are different and they jack the front up an inch or something :P).
Also, are they worth it (i.e. are they any good) or do they just carry the sticker?
Cheers heaps,
-Dan
https://www.sau.com.au/forums/topic/356367-r33-gtr-suspension-in-r34-gtt/
My main worry with using coupe coilovers - and worse - GTR coilovers is that they're designed for a much different weight distribution than the sedan, and whilst they may fit - will ultimately result in a poorer ride than something specifically setup for the sedan.
From what I understand with the GTR coilovers on even coupes - they're designed for a greater weight over the front wheels that the GTR engine has, so are setup to compensate for that. I think this would be even worse on the longer sedan shape.
This is going on what I've read, and what others on this forum have said - so take it with a grain of salt :)
Nah your right, its shit.
Its actually softer than the stock gear + far too low (so scrubs on the guard) and bump stop happy.
new thread;
http://www.skylinesaustralia.com/forums/topic/358162-suspension-for-a-street-r34-gtt/
Worth mentioning though is the fact that nissan lists exactly same shock p/n's for R34 coupe and sedan. They also have the same wheelbase, so unless you drive with loaded boot, weight distribution is very close to sedan's.
  • 9 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
