Mirrors: $40 each or $60 the pair
GTS-4 Brake and Calipers and everything else brackets and lines make an offer
ZEX Nitrous Kit looking for $350 includes 10lb bottles, dual purge outlet lines, Green LEDs, bottle holder, braided lines etc...retails $550 from US
Rear Seats $50 pickup only from Melb
Rear Floor Mats $15
PM if you want pics or to make offers
Cheers
Dan
Btw: R33 Mirrors are Series 1 and not a standard colour so they would need to be painted
ZEX Nitrous Kit will take $300 pickup in Melb this weekend
Possibly Mirrors sold...
Offer may be made for Nitrous Kit
Atm not looking at splitting up brake parts as I can trade this to a mate for his 31 to get some work done on my car, but will sell for the right price
Rear Seats and Floor Mats still available
Pics upon request if needed :)
Also my mates just given me his R34 Original Gauge cluster from the centre console if anyones interested PM offer for that.
Parts still available:
R33 Series 1 Mirrors (Custom Colour, would need to be repainted) $40 each or $60 the pair
R33 Rear Floor Mats $15
R33 Rear Seats $50
R33 GTS-4 Factory brake kit includes calipers, lines, rotors etc...make an offer
Zex Nitrous Purge Kit $300
R33 GTS-4 Brakes Offers over $200
R33 Rear Seats Series 1 Coupe $40
R33 Rear Floor Mats Series 1 $10
R33 Side Mirrors $30 each or $60 both
R33 Spare Slimeline Wheel $10
R34 Centre Gauges factory, not the housing only the gauges. PM offers
Zex Nitrous Purge Kit (Dual outlets) $280
is there a difference between GTS4 brakes and GTST brakes?
I need a set of calipers for my cressida to do a brake upgrade
just got to make sure they are the right ones
cheers
Yeh GTS-4 are awd compared to gts-t are rwd. However calipers are the same.
Not looking to seperate but whats your offer for calipers though?
Still available:
All Series 1 parts from 1995 model
R33 Mirrors
R33 Rear Seats
R33 Rear Floor Mats
R33 GTS-4 Brake setup, calipers, rotors, pads, lines etc...
Spare slimline wheel
R34 Standard Gauges from centre console, not the moulding just the gauges themselves
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
