Hi,
I am relisting my mates PPG DOG box for a GTR as he has gone OS and wil be for some time, I have full access to the box (its stil in the car at the moment but can pull it out for further inspection)
His old post is here http://www.skylinesaustralia.com/forums/topic/347186-ppg-dog-box-suit-gtr/page__p__5610678#entry5610678
But here is the jist of it:
For Sale PPG straight cut 5speed gear box billet selectors and sandwich plate was an option the full monty box from PPG
used only for street driving not even 2000kms on box i paid 13000 from hi octane racing in sydney
billet input shaft its the bigger one of the two options and the gearbox factory in sydney put it together for me
1st 2nd and third are noisy 4th 5th are very quiet
Its the best main shaft you can get the 1200 dollar upgrade same input shaft all the big gtr boys use drag racing...... comes complete with transfer case and at extra $$$ can sell Direct clutch performance Clutch
The original asking price was $10,000
But i have been orthorised to drop the price to $9000
Any in inquieries please call or via forum.
cheers
https://www.sau.com.au/forums/topic/356776-ppg-dog-box-suit-gtr/
Hi All,
I have called HiOctain today to ask about the gear config and they confirmed that all the gears only come in a 4 speed or 5 speed set and this is a 5 speed so all gears must be straight cut dog engagement
Cheers
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
