I've done some searching but couldn't really find what I was looking for.
I know greddy made these strut bars, but are now discontinued. I also found cusco still make them.
but I was wondering if anyone has used anything other than these? something from a different model Nissan. I've been told that r32 mounts may fit but will need a custom bar. I'm keen to save some money and not pay $250+
any help would be appreciated.
https://www.sau.com.au/forums/topic/356789-rear-strut-brace-for-c34-s2/
well given that GT-R suspension goes into the rear then i'd assume the top hats are the same as GT-R's - which means the outer mounts off any GT-R will fit - then you just have to get the measurement in between the towers.
maybe try for a whiteline or something with a rose joint in it, which will allow you to fine tune the length?
When you say GTR, I assume you mean R33.
R33 GTR rear strut braces do not bolt to the top of of the towers like the C34 ones.
They bolt accross the back of the tower on studs
don't know? don't have a GT-R - but i do have R34 GT-R Coilovers so i just assumed the top hat pattern would be the same - and i'd say knowing nissan - that there would have to be other skylines using the same pattern with braces that bolt to the towers.
good to know though. your search continues! but seriously, yahoo japan - second hand - contact aaron at import monster and he'll get it done for you - save yourself the hassle.
actually, contact him regardless - i know he has a few stags that he is wreckign and might have a strut brace for you. if not, he will have a heap of braces that he could try in the back of his personal stagea.
i know the 33 rear strut braces don't mount to the suspension hats, they bolt down else where
keen to see the development of this, seeing as i was too poor to get it very far over summer
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
