Smasa & Shannons Insurance Presents The Old School Vs New School Dyno Shoot Out
SMASA & Shannons Insurance Present the Old School Vs New School Dyno Shoot Out
Saturday 14th May 2011
Southern HiTech Dyno Tune, 8 Emanuell Court, Melrose Park
Cost $45 for 3 runs, includes print out. Goodies on the day, as well as trophies
For more information please call or sms Cara on 0466 481 820 or email [email protected]
Here are the dyno classes for the day:
Rotary Naturally Aspirated
Rotary Forced Induction
6 Cylinder Naturally Aspirated
6 Cylinder Forced/Blown/NOS
8 Cylinder Naturally Aspirated—up to & including 6L, and 6.01L and above
8 Cylinder Forced Induction—up to & including 6L, and 6.01L and above
8 Cylinder Blown—up to & including 6L, and 6.01L and above
8 Cylinder NOS
  • Nope 4
  • 2 months later...
it went very well thanks. had 24 cars but they were all good quality cars with decent power for their respective set ups :)
photos can be viewed here http://www.carabertoliphotos.smugmug.com
Yeh let me know, my car will be done by then. Won't compete with those high numbers, but will at least be over stock :) My brother will possibly have his car ready. Do they have provisions for 4wd (GT'R's?)... might get someone else interested to.
Cheers :)
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
