For Sale
R32 GTR 328rwkw
Full respray grey, 6 point cage, forged pistons, shotpeened rods, head work, cams, apexi power fc, garrett 28/60 -5 turbos near new, apexi intakes and pods, 700cc sard injectors, 040 pump, 100mm thick custom cooler, hks triple plate cutch, apexi coilovers, 2 way diffs front and rear. turbo back exhaust, drift wheels, 235 on front 255 rear. custom whiteline suspension, also has front and rear sway bars. apexi gauges on pillar, apexi boost controller.
i have probably forgotten a few things, alot of time and money has been spent on this car. made 328rwkw on 21 psi, have dyno papers.
$24,000
call 0421 173 880
Edited by laspy
https://www.sau.com.au/forums/topic/357016-for-sale-r32-gtr-328rwkw/
  • Replies 59
- Full Respray in gun metal grey using quality standox paint
- R33 GTR driveline
- Engine rebuilt forged pistons and shotpeened rods
- Head full port and polish with HKS cams and JUN valve springs
- Gearbox rebuilt and has HKS Triple plate clutch
- Garrett 28/60 -5 turbos
- Apexi Power FC
- Sard 660cc injectors
- Bosch 040 fuel pump
- Z32 Air flow meters
- ATS 2 way front and rear diffs
- Custom 100mm cooler
- 3 1/2 inch turbo back exhaust
- 6 point Jap cage in black
- Apexi N1 coilovers
- Custom whiteline suspension
- Front and strut braces and sway bars
- Apexi air pods
- Hard pipe kit
- Greddy oil and boost gauges on pillar
- Nismo 320km cluster
- Short shifter
- Custom catch can
- Slotted rear rotors and crossed front rotors
- Greddy Profec B boost controller hi/low setting
- Turbo timer
- Dished drift wheels 245 front 255 rear
- Alpine head unit
- painted engine covers and polished turbo pipe.
Alot of time and money has been spent on this car. Very sad to see it go,
havent got the time for it anymore. engine is still brand new, Great car to
drive. Made 328kw atw on 21 psi, have dyno papers.
$26,000ono
call 0421 173 880
Edited by laspy
few things i missed, here is a revised write up of the car. still for sale
BODY
- New windscreens and rubbers
DRIVELINE
- R33 GTR engine
- Engine rebuilt
- CP forged pistons
- Shotpeened rods
- Race bearings
- Linished and balanced crank shaft
- ARP main bolts and head studs
- Cometic head gasket
- HKS cams
- JUN valve springs
- Braided lines
- Apexi Power FC
- ARC intercooler
- Custom intercooler piping
- Z32 air flow meters
- Apexi air pods
- Hard pipe kit
- Custom catch can
- Turbo back exhaust
- ATS 2 way front differential
- ATS 2 way rear differential
- R33 Gearbox
- Rebuilt
- HKS triple plate clutch
SUSPENSION
- Front and rear strut braces
- Front and rear sway bars
- Slotted rear brakes
- Cross drilled front brakes
COSMETICS
- 6 point jap cage in black
- Greddy oil gauge
- Greddy boost gauge
- Pillar gauge holder
- Short shifter
- Aftermarket gear knob
- Turbo timer
- Dished 17" drift wheels
- Alpine head unit
- Painted engine covers
- Polished turbo pipe
- Nismo oil cap
- Nismo Radiator cap
- New battery
- T-bolt clamps
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
