I've just been waiting for a good SP game for ages. Coop is confirmed, too!
I used to play the original Ghost Recon with my mates alllll the time. :) $45 preorder for limited edition, ozgameshop
cheers for the heads up :thumbsup:
Edited by LoNg_ShaNks
https://www.sau.com.au/forums/topic/357024-battlefield-3/#findComment-5725439
I think the PC version is going to kick some major ASS!!!!!!!!
Even BF2 on console tended to have some framerate issues...
Nevertheless I'm going to hold out before fully upgrading the PC to handle this kind of game.
https://www.sau.com.au/forums/topic/357024-battlefield-3/#findComment-5744516
so, anyone seen the full 12min video to the one that has already been posted in this thread?
you can download the HD file here: ( 1.2GB)
http://www.fileplanet.com/219665/210000/fileinfo/Battlefield-3-%27Fault-Line%27-Complete-12-Minute-HD-Gameplay-Footage
https://www.sau.com.au/forums/topic/357024-battlefield-3/#findComment-5767947
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
