I'd look at breaking lease and moving somewhere cheaper for 8 months, but bottom line would be the same with fee's and moving costs... I'll keep looking...
Have you been advertising on the various real estate sites for a room mate? also try gumtree.
Morayfield this week the usual 7:30 time slot question is what does everyone have a hankering for? let me know what you want to eat.
arvos again:( but at least ill have my car, withdrawels f**king suck ><
+1 to clints pc brain, fixed my pc to be faster then my commodore.
I will be there next week though, hopefully!!
awesome line :thumbsup:
Speaking of pc's... Who wants to come over and assist with... Heck, put windows 7 on the machine i have here?
well turns out im not working today. but i have decided to put the back of the Line back together....hasnt had a back seat since coilovers were installed :(
i've got everything i need to make little extentions for the adjusters so i dont need to pull the back seat out every time i adjust the shocks (which ive realised makes a HUGE difference to the way it drives, and street soft will not work well on the track.)
so that will be my day
why have 2 cars if your strapped man that's 2x rego and upkeep that's just making a money pit, Any luck on the room mate front are you advertising everywhere including local shopping centre BB's?
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
