what mods are you running to make 210Kw?
Full 3" exhaust
Pod Intake (hks mushroom)
Power FC tuned by RPM Morayfield
Yellow Jacket Coil Packs
Return flow IC (just been swapped out as it was giving me severe pressure drop above 5k 4.5psi) Now a HDI GT Spec Cooler
If I have done anything else I have forgotten what it is.
It was running 204.4 KW after the tune with a leaking turbo gasket after fixing that it was rocking 210kw (turbo only had 2 nuts on it when I brought it so I discovered)
I am hoping that with the new cooler not dropping pressure she will produce 220 - 230kw as the sheet was looking like it would do that if it didn't have that pressure drop.
next mods will be injectors, pump and turbo I guess maybe even a z32 afm depending on if I get power hungry again.
Yeah Clint should be alot better once she's has the mid and top end of the tune finished. Ya bastard ya got in front of me LOL.
Yeah I was gonna come down Friday arvo but I was rooted after fitting the cooler so I rang Pete, I'll let Pete work his magic and see what she makes and If she will need a new clutch to go with the power.
How was Harry's the other night?
Wasn't to bad. quite a few cars. They filled the other side of the road car parks. Cleared out pretty quickly though.
so what is everyone up to today?
was going to be a car clean and sort out day. but its too windy outside to clean it. and i got a sic girly to look after :mellow:. so mines a quiet day....might reassemble the back of my car this arvo.
got my coilover adjuster extender thingy's sorted and the inside of my car back together and clean....about bloody time.
I ended up using a 1/4inch universal joint and medium lenght 1/4 socket extention on either side with a little black cap on the top. the original idea was to make them out of anything other than Metal as metal can be heavy and rattle, hence why i had some timber and rubber ones made up (which didnt work), so metal it is. hopefully they dont rattle to much.
Hmm, im thinking morayfield this week. And if anyone is keen id like to get something happening during the day, even sat/sun arvo. Game of footy or cricket, something different.
As for this week, yea im not sure.. We could go to our usual spot but turn ups have been bad the last few weeks, people loosing interest or w.e
However, id like to get pictures of each car as i am extending my knowledge base on web design. (i would be making a website to do with our pride and joys)
You will b abke to upload, comment etc at other peoples profile!
yeah guys im in for a local feed this wednesday. happy laps is this weekend....but i wont be going to that either. car needs new brake pads and im far too lazy/busy to get it done by then.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
