ha ok, hopefully their are some lights on there somewhere, if not we will kick it in the dark idc! something different then the usual.
Should we meet at cappers around 7pm?
capers @ carseldine @7?
I think they mean capers in Morayfield, I am Comming out I can get in trouble for it later. see ya's at capers @ 7
Edited by RandomHero83
Not too bad, didn't think the footy would have been taken out last night, but was good to meet more people.
Also, thanks for the scare fellows, I should good to get some things done properly next weekend
Like clint said last night, we are more then willing to help ya show you some of the stuff that ya need to fix.. (im still new, sorta) but i know my way around alot more now :P
Nice to meet you both, where exactly do you live?
live in lawnton mate, and like wise, was great meeting more members, and trust me, i will be picking brains for input, i like input :P
also, i really do appreciate the fact that everyone is willing to help and show me things i didn't know.
going to harries tonight, anyone keen to join in?
Due to events this week I am going to drown my sorrows for a bit and maybe do some shopping. I may be keen to go to munchies tomorrow night and check it out. Did you get your license back today Joe?
so you are going?? im in next time but not this weekend :( the early morning road trips down to Willow bank used to be fun in a few older cars heading to the Jambo at some silly hour of the morning. dont see why a road trip like that for happy laps wouldnt be as much fun. route 5 around the west side of the city is a bit of fun that early in the morning :)
You know you want to.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
